Epson Scan will overwrite files
lynnb
10:36 AM
I've just discovered that Epson Scan will overwrite files without any warning. This discovery has led to me changing my file naming system for scans.
The discovery happened when I realised I'd put an incorrect camera name as part of the file name string, and then tried to rename it in Finder (= Windows Explorer for PCs) eg. FE2_HP5_D76_R48_001.tiff renamed to F80_HP5_D76_R48_001.tiff. Finder gave me an error warning that the file name already existed.
I halted the batch scan and renamed the output file to avoid future conflict. Then I discovered that the original file had been overwritten by the new scan. Of course I still have the original neg and can re-scan it.
This is annoying - I would've expected Epson Scan to give warning if an output file name conflicts with an existing file in the same target directory.
Also annoying is that I can now only run Epson Scan on an older Mac running Snow Leopard. It doesn't work on Mavericks, as far as I can tell.
My file naming protocol now starts the file name with YYMM. That should avoid future problems.
EDIT: there is a check box in Epson Scan that will avoid overwriting files - thanks for your help guys!
I'm like 95% certain there is a setting under the file save properties that says "Overwrite any files with same name." ...
Yes, it has this setting, somewhere :)
My naming convention is "Camera_Lens_Film_Developer_M_Y" and Epson scan utility is set to add increasing numbers at the end.
Here it is....
Uncheck this box
See attachment
I'm downloading the latest driver and scan utility for the V700 for OSX 10.9... download file name is Epson15897.dmg.download - which has a date of 24 January 1984!!!!
At home I use Epson Scan on Mavericks. I had to ask Epson Customer sevice where to find it and I received a quick answer. When back home I can check about and eventually I'll give some more infos.
I'did'n kno about deleting files with no warning, of course it is very disturbing.
robert
I never liked using Epson Scan at all. For trivial things (scanning documents), I use OS X's Image Capture.app. For photographic work I drive my scanners with VueScan.
G
