rami G
Hi all,
like others, my R-D1 remains a favorite in my bag, along with the M8. I am, however, tiered of the scratches I am getting on my glasses. I remember someone saying, a while ago, that one of the old Nikon bodies has a matching eyepiece that matches the R-D1 and can prevent such scratches. Does anybody have any information on that or on any other solution?
Xmas
rami there is a search facility and
Ben Z said
Easy-to-obtain corrective eyepiece diopters for the Nikon FM, FM2, FM3A, FE, FE2 and indeed the old Nikkormats and Nikon F, F2 and F3 (not the F3HP) work on the RD-1...
Noel
Noel
furcafe
rami G
Thank you very much, that is very helpful.
btw, I did use the "serach" function before... hope my question did not cause a trafic jam in the highly crowded rd-1 forum...
rami G
forgot the: "; >)", so here it is: ; > )
jlw
Rangefinder camera pedant
rami G said:Hi all,
Doesn't your R-D 1's eyepiece have a rubber ring on it? Mine does; I thought they all did. I use it with glasses all the time -- no problem.
If yours has a non-standard eyepiece or if the rubber ring just came off at some point, maybe the easiest solution would be a replacement stock eyepiece.
rami G
jlw said:Doesn't your R-D 1's eyepiece have a rubber ring on it? Mine does; I thought they all did. I use it with glasses all the time -- no problem.
No, it doesn't, maybe it fell at some point. Do you have any suggestion how to get the replacement stock eyepiece? just contact Epson?
RichC
The Nikon one is almost identical, and the Voigtlander Bessa one is identical; either will be easier to get, and cheaper than, the genuine Epson one.rami G said:No, it doesn't, maybe it fell at some point. Do you have any suggestion how to get the replacement stock eyepiece? just contact Epson?
PS: R-D1 eyepieces are described in my R-D1 FAQ (see sticky post in this forum).
rami G
RichC said:The Nikon one is almost identical, and the Voigtlander Bessa one is identical; either will be easier to get, and cheaper than, the genuine Epson one.
thank you very much, you have a great source out there. Extremely instructive.
