Fed2 horizontal adjustment
robin a
11:11 AM
Pace,Florida
Hi,I have a problem with "ghosting" on my horizontal focusing.A slight second image.What would I do to correct this?I have adjusted the screw for vert.but can't find how to do horizontal.Thanks in advance for your help.......Robin
The ring for the horizontal ajustment is found beneath the covering ring of the rangefinder. Beneath it is a ring bearing a smaller ring with a glass, by turning this smaller ring you can ajust the rangefinder vertical.
The screw adjusts the horizontal, vertical alignment is by rotating the prism behind the front RF window ring. I think you may be confusing vertical and horizontal meanings...vertical is up/down, horizontal is left/right (think of the horizon).
Thanks Guys,I got a little off track on item #17 on the Sticky for Fed2's.There it says vert. is done with the removal of the rangefinder window.It's done with the screw.Working good now. Thanks...........Robin
