shawn
And if you want to do the new flash fad of 'beating the sun', it is just as easy to use a ND filter. They cost less than an HHS flash, but they don't have the screen interface of a new flash.
Here is beating the sun using an 3 stop ND filter:
How does a ND filter help 'beat the sun?' The point of a HSS flash is you shoot at a higher shutter speed so that you reduces the suns input on exposure without effecting the output of the flash, assuming the flash is faster than the shutter speed. You are changing the ratio of the sun to the flash. A ND filter will just cut down the flash and the sun together without altering the ratio between them.
If your flash is strong enough the other option is just to overpower it.
For example this is with pretty typical fill flash:
and these are from the same time 'beating the sun' by turning up the output and using a snoot.
That is with a Flashpoint StreakLight 360 Ws.
Shawn
