Fernando2
Heres a review of the Epson V700 that i wanted to get (skip to the image quality paragraph). It states that the actual dpi the scanner was able to reach was 2300dpi, compared to the 6400 dpi that is indicated by the manufacturer.
Whats your take on this? And while we at it, i do need a affordable scanner 😀
Hello papo,
the question of claimed vs. actual resolution is really complicated, unfortunately.
I've written a review of the V700/750 some time ago (in italian, but I hope illustrations and measurements may be of help) http://www.effeunoequattro.net/htdocs/freecontent/FC_ProvaV700/index.php
To summarize: yes, expecially for consumer flatbed scanners, manifacturers like to publish "theoretical maximum sampling frequency", not resolving power.
And while it's generally good to have some headroom for sampling frequency (sensor resolution) vs. scanner lens resolving power, in most cases the difference is enormous. 🙁
As others said, the weak link is the scanner lens (and anyway, those flatbeds use staggered sensor arrays instead of true 6400ppi-capable linear sensors).
The V700/750/800/850, with very careful technique and 3rd-party holders (which grant much finer focus adjustment) are able to (barely) resolve about 40-45 x 60 line pairs/mm, when scanning at 6400ppi. That may translate to 2100x3000 "real" ppi.
If you shoot 120 film, that may be enough for quite large prints, with proper sharpening.
For 35mm, well, a dedicated filmscanner (Reflecta, Pacific Image etc. if buying new) would do quite better.
Fernando
