Filter and hood for russian Elmar copy
jamiewakeham
Long time lurker
9:54 AM
Hi all
OK, I give in. I con't understand Leica's naming system at all.
I'mmtrying to work out what size/fit filter I should get for my Zorki 1's collapsible 50/3.5 elmar-a-like. And, for that matter, what type of lens hood. I assume it's actually easiest to buy genuine (used) leitz, just because there's so much of it about - they seem reasonably cheap on eBay.
How do the filter and hood fit? I assume the filter pushes on, and the hood somehow connects to the filter?
Thanks in advance,
Jamie
36mm push-on filter. Just like the real Elmar. I only have the Leitz filter, but not the hood. I've yet to see the hood come up for sale on Ebay. I'll likely be making my own from a plastic bottle.
Heres my solution, take a standard push on FSU filter and knock the glass out of it. Now it will press fit into the back of a 40.5 filter,although some are a little looser and need a drop of epoxy.Remove the glass from the 40.5 and now you have a neat filter adaptor. This works great as on a shoot you only need one size filter if you take the collapsible and say a J-8 along...........
