Finally and official statement by Zeiss on the 85/4
It looks like an old long lens design, The black late Canon 100/3.5 is about $120 why Zeiss 85/4?
Why, because it's not a Canon POS. It's 85mm. It's an original Carl Zeiss design, not a ripoff of a Carl Zeiss design. It's multicoated. It should be built to a higher standard. It's new. It won't need to be serviced.
I wouldn't be concerned with performance. These days, Carl Zeiss doesn't make lenses that are dogs.
David
Wow - something old is something new! Very classic, indeed.
sorry, but no it's not. at infinity it measures 75mm not counting the flange or 81mm counting the flange. at close focus it is around 92mm w/ the flange. not sure where you got your info, but it seems to be wrong.
the info is right there on the official zeiss site. under the technical specifications, the length of the 85/2 sonnar is listed as 100mm.
you'd better write a message and tell Zeiss they are wrong.
i measured the actual lens, so mine are correct.
mistakes are made on websites all the time, but i don't have the time to email zeiss about it. i have much more important things to do such as reading this forum 😛
Ain't that the truth! 😉 More power to ya!
Thanks for sharing the info. Would be great to see some photos from the lens, too, but given the climate on RFF lately, I'd advise against it, actually, for the time being, unless you put it in W/NW.
Wonder if that means there are discrepancies in the other measurements, too? Or perhaps Zeiss march to their own beat and measure with their own yardstick?
FYI the ZM lenses I've weighed (25/2.8, 28/2.8, 50/1.5) have all been about 15-20 grams lighter than the weight listed on the Zeiss website.
I suspect that the zeiss lens photos on their website may not be photos at all. With todays cad programs used with ray tracing software, it is easily possible to create photo realistic images from designs and without the use of a camera.
Look at the filter thread on the enlarged versions of the images. Most of them are just parallel lines. And also many of those images have the lens fron element protuding up into where the filter glass would go.
Yes I should have better things to be doing🙂
