weetsie
so i did some developing for the first time ever the other day and im very happy with the results.
i used the kodak 6 bath E6 kit and developed a roll of velvia 50.
now, first problem i had was working out how long to use the first chemical for, "first developer"
it says in the instructions 6-7minutes and next to it it says you can vary this time from 5:30 to 8:00 minutes but once you have chosen a time you should stick with it within +/- 5 seconds.
can someone explain what that means?
ok second question, the last chemical to be used was the "final rinse" and after that step it said to dry the film.
i used the final rinse and then opened the drum but it was completely full of foamy bubbles so i washed the film with water, should i have just hung the film up and dried it with the foam on it?
and finally my pictures came out a little under exposed, is it possible to tell if that was done in the camera or in processing?
here is one of them:
