MrBuhl
OK - here are a couple of photographs from my first two through the GSN.
They were both HP5 developed in XTOL 1:2 for 12 1/2 minutes then scanned on an
Epson 3200. I don't really like the scan quality but I like the exposure from the camera. (anyone have a magic bullet for B&W printing on an Epson 2200 inkjet to remove the color cast?)
Hope you like them.
Ed
http://www.rangefinderforum.com/photopost/showgallery.php?cat=5136
Hope you like them.
Ed
jon_flanders
They look good, it appears you have a winner in the GSN lottery. Good pad of death, working electronics.
Enjoy the camera.
Enjoy the camera.
MrBuhl
Thanks Jon - I do have some doubts about the pad of death though - the hi / lo lights do flicker a little when they come on - I thought I read they should be steady?
Iskra 2
Kodachrome Rules!
Great Pics! Now try some Leica film .... ahem....Kodachrome
What a great little camera. Someone mentioned in a thread on PN that there are people in Japan that modify their Yashica lenses with a LTM. Can you believe that? I can.
Pherdinand
the snow must go on
The pad of death is not necessarily the reason for flickering lights. I replaced the pad in one of the two GSN's i have and the lght still flicker, If i remove the bottom plate and plow some air into the hole, they stop flickering for a while, but then it comes back. It should be some electrical contact issue. But it does not bother when shooting.
MrBuhl
Thanks! I appreciate the additional info Pherdinand!
JoeFriday
Agent Provacateur
my GSN has the same flickering lights.. and often require a little 'warm up' by working the shutter release button a bit before they kick in.. many people have the same problem with their GSN's
Poptart
Screw Loose & Fancy-Free
Can someone please explain PoD?
R
ray_g
Guest
Poptart said:Can someone please explain PoD?
Here's a good place to start: http://www.yashica-guy.com/document/repair.html#nine
Fedzilla_Bob
man with cat
I think greyhoundman and others gave a description of the problem in another thread a few eeks back.
Here is another thread describing another symptom the GSN can exhibit-- sizzling-
http://www.rangefinderforum.com/forums/showthread.php?t=5337&highlight=sizzling+gsn
Another member suggested that regular use will relieve the meter lamp problem eventually.
