Fitting new curtain ribbons to Leica iiic - help!
olliewtf
2:01 PM
Hey all,
I'm on my 4th attempt at fitting new curtains and ribbons to my iiic. It's been a steep learning curve, but yesterday's attempt was so close to being successful I'm loathe to start from scratch again!
Shutter was firing perfectly until I fitted the cage, and all the bits that hold it in. The second curtain would hang just before fully closed on nearly all shutter speeds. I knew something was wrong, and suspected that maybe the ribbons, as they wrap around the curtain rails, double over and are stitched, were potentially fraying slightly and were generally too bulky - causing the curtain to slow as it makes contact with the 1st curtains ribbons, where they too attach to the opposing rail.
So I took it all apart again to see if there were any signs of rubbing, and sure enough, the ends of the ribbons that were folded over the rail were fraying, as was the stitching ever so slightly, from rubbing.
So my plan is to use my contact adhesive to smooth off all the fraying, and let it dry for a minute or two before clamping them somehow to get them as flat as possible. I'm hoping this will create a smoother surface, with no fraying issues, and the shutter will fire correctly for years to come. I could also use simple UHU superglue for this - my feeling is that the adhesive is probably a better shout.
So - is this a potentially sensible solution, and how the hell do you DIYers ensure that these parts move smoothly? My stitching isn't machine like, but I was sure to add as little bulk as possible - as this is why my first attempt failed.
Option C is to start over, maybe invest in some finer thread, glue these parts after stitching and also have the fold over of the ribbon end around the rail lie opposite ways for each curtain - though I'm sure this doesn't make too much difference.
Thoughts very much appreciated! I'm very, very close to success.
Pic for reference - looks bulkier than it is due to the fraying, but just so we can all see what the hell im on about!
Okay update - I used superglue to smooth off any fraying and pressed each end.
I then noticed that the second curtain was still hanging on slower speeds, and eventually put this down to the fact I hadn't glued enough of the curtain to the drum - so the excess 'flab' would bounce against the crate and slow the curtain, making it nonparallel and jamming it. So I sorted that out.
Results were better, but very occasionally on certain speeds it would still hang - this seemed to be resolved with sufficient tension, but surely that can't be right? Either way the amount of tension that would solve this was in the ballpark anyway.
My other problem though is that 1000sec wont work without a lot of tension on the first curtain. Its louder than my Zorki. what could be the cause of this?
I'm wondering whether to go ahead and replace the second curtain and ribbons again, for fear that things are a little askew and causing alignment and rubbing issues...
Any insight greatly appreciated!
I found the instructions on aki-asahi.com helpful when rebuilding my FED-2:
http://aki-asahi.com/store/html/shutter-curtain/inst/01.html
Nevertheless, it was my first attempt at such a repair and I needed to redo several times. I deviated a little in using Cemedyne Super-X throughout, because I had some doubt as to how long double-sided tape would last. I didn't attempt to stitch.
Besides a general lack of precision with my first attempts, it's possible that the fabric and ribbon I was using was too thick. I switched to Aki-Asahi parts. I also ensured that the folded ends of the curtains and ribbons faced away from each other.
In the end, I got a smooth-running shutter and did not need to deviate from stock tension settings
Thanks all.
I did a bit more digging. FYI I already have the nobby sparrow guide, very useful.
One thing I regret not doing is, as you say Jeff, facing the folds away from each other.
Regardless, this isn't my issue now. the amount of tension the 1st curtain needs to achieve 1000 is far too much, so there is a problem.
My hypothesis is that the 2nd curtain isn't glued in the right place. I followed nobbysparrows suggestion of advancing the 1st curtain 1cm, then creating a 2mm overlap and gluing - rather than gluing the curtain to my scribe line from the original set up. Either way is probably good, either way I think I got it a few mm off.
A few articles mentioned that if you're struggling to get 1000 sec, and/or the 2nd curtain sometimes hangs, this can be down to incorrect placement. I cant begin to get my head around why, but its a sensible conclusion to my problems. I may go ahead and make a new 2nd curtain (again!) face the ribbon folds away from the other (still not perfect but should be fine) and take extra care to match the curtain to my scribe line. I may glue it to the drum before gluing and stitching onto the rail, to make this job less fiddly and more accurate.
Thanks again for everyone's help!
I will get there in the end haha
You didn’t mention, so I’ll ask. Did you clean and lubricate all the bearing surfaces, especially the shutter brake gear? I just got an old iiic and had similar issues to what you describe. After thorough cleaning and good lubrication it’s running fine at all speeds.
You guys are braver them me. I'd just send the thing to Youxin Yee, pay what he charges to get it right and just think about shooting the heck out of it when it returns.
Well, if one doesn't find any challenge or enjoyment from this kind of thing, then sending it off for repair is definitely the sane choice. Fixing old cameras is a separate hobby from shooting with them. Both can be very rewarding :)
Ive always been one to throw myself into repairs - I hate not having a go first, and the learning curve is very valuable!
Peter, re the brake and bearing surfaces - ive cleaned as much as I can without dismantling the drum and crate. It appears to be working in that respect but ill give it another soak and oil.
I re-glued the curtain last night, leaving a slightly smaller overlap than previously. This has worked better - 1000 fires correctly now without the need for loads of tension, though without a tester im not sure if its as 'relaxed' as it should be considering all is new.
the 2nd curtain will still hang on B setting if it has a low tension, but I have a hunch that this is possibly normal as the amount of tension needed to stop this seems still quite soft. My only concern is that I did see an article that showed the second curtain should be a set distance from the edge of the frame when cocked - and i think, though i need to check, that mine is sitting a bit further back than recommended - i wonder if this would cause issues? but that for now is an imagined problem as I havent measured it.
Im going to try a local camera repair shop and ask if they can test the tension for me - so long as its not extortionate! the old tv method - would it not work to ahve someone upload a video to youtube of an old tv and use that video as a tester? or would the 'timing' stuff get lost when compressed and made digital?
so far so good. Would love to get this all working for the weekend, im off to prague! Failing that the rollei is coming with me lol.
thanks for everyones input!
I think I can answer the old TV method question. No, I believe it will not work if you try to use a youtube of a TV video. What is needed is the way the tv signals are shown on a CRT screen and that is going to be lost if you look at it on an LCD screen as fitted to modern laptops and computers. You'll have to find a real live old TV somewhere...
John Mc
John Mc
This is correct. The reason a cathode ray tube TV set can be used is because it displays an image refreshed at specified hertz. It's the transmission signal that is key. A CRT set not tuned in to a transmission is of no use in checking a shutter. If a screen displaying a recording of a CRT set does not mirror the same hertz as the original signal it will not be much help.
Newer television sets or computer monitors seem from my limited experience trying them to be much less useful for shutter checking. Although I have a professional quality tester I still keep a small CRT set on hand which I will use occasionally for a visual inspection across a fp shutter gate.
Cheers
Brett
I hate the local camera shop. £80 just to quickly check my shutter speeds. ugh.
It'll have to wait I guess. I'll do it by ear and eye (lol) for now and I'm sure I'll be in ballpark for a test roll.
Microphone, a computer and some free audio recording software (like Audacity) where you can see and measure the length of the shutter sound works too.
I read that didnt work so well above say 1/30th on focal plane shutters?
I could make the photo resistor plug, seems simple enough - details on the lomo page about the app.
that might be a shout to be honest, bollocks to paying someone to spend 2 minutes telling me if it works or not haha
If you have an iPhone or other smartphone with slo-mo video ability, you can check the gaps to see if you’re getting even exposure. It won’t help you know if your speeds are correct, but even exposure is probably more important.
I think 80 quid just to pop your camera on a tester for a couple of minutes is a bit over the odds too Ollie, and I do congratulate you on having a go at the repair and doing fairly well so far. But consider the possibility that you may want to do future repair tasks (and why not, it's a viable way of acquiring equipment that might otherwise remain out of reach price-wise). If so, for double the shop's ask to check one camera, once (possibly rather less, depending on the model you choose), you could own your own electronic one which you can use many times, with many cameras. It's not such a silly idea because people who successfully repair a camera once seem, from my observations, to often subsequently go on to other projects. ;)
Cheers
Brett
