olliewtf
Brett - spot on - it is something to consider for sure.
I am wondering how far out the timings will be - im sure theyre ballpark anyway when you consider film latitude etc. As Peter suggests, even exposure is more important.
I made headway yesterday - built up the slow speed parts and the rest of the crate. Forgot to check that the spring was properly located on the escarpment, which had me scratching my head for a while!
Interestingly all slow speeds to the left of 30th are working (down to 1/10s) but to the right (round to T) work only once, when first set to that speed, then after re cocking fire at 1/30. I will most likely never use them, but it bugs me that this camera has had all this work done so I would like to fix this problem if I can!
Any ideas? I cant work out why, for example when i set to 1 second, it will fire and trigger the slow speed timer, but then when i re-cock and fire again, it no longer engages it? If I move the speed back to 30 and then back to 1 second I can get it to fire it again most of the time....
Either way Im very close to finnishing and might risk taking it away this weekend - though it might be wise to run a test roll if I can find time!
Still need to fit the new beam splitter mirror and clean the viewfinders.
