Harry Lime
Practitioner
That's some very illuminating information, Bill.
So, it really sounds like there is no way to completely emulate the look you got with flashbulbs (especially it's effect on motion), unless you use... flashbulbs.
Using a very large reflector etc will help to get you closer, but you will always have the problem of the actual size of the source. In movie lighting it is known that the size of the bulb gives different looks. As an example a carbon arc light has a very tight and intense light source, like an arc welder, producing very hard light with extremely crisp shadows. Standard tungsten bulbs deliver downright 'soft' light in comparison. HMI fall somewhere in between, although bulbs for these lights are about the same size as tungsten.
I looked up the tech specs for the Hasselblad D40 (Sunpack) flash. Even that unit has a burn time of 300-800ms, which is a lot faster than the old bulbs.
Maybe I need to go back to some very old flash units from the 60's and 70's to find something with a longer burn time, around 100ms. Of course none of them will be as slow as a flashbulb, but it would be interesting to see what something like that looks like in conjunction with the slow 1/50th sync speed of a Leica M.
