Focus test with lux 75/1.4 and M8 @ 1.5m distance
ampguy
12:22 PM
This set of images was taken at 150 cm away from primary central focal subject (red Cheez-It box) to M8 image sensor, but otherwise is similar to my 35/1.4 lux and rebuilt Jupiter-8 focus shift lens tests.
My conclusion examining at 100 and 200% crops is that my Summilux is optimized for around F 2.0, which will help me know, especially at min distance (0.7m) that I can focus ~1-2 cm deeper and retain sharp focus that amount in front. Much easier than my pre-rebuilt J8 which back focused and I had to focus backwards in the air at min distance!
This is probably as perfect a lens as we will see in this millenium, IMHO 😀
test results here
summilux 75 testing
summilux 75 testing
thank you for doing a proper job on this test. i will get out my cereal boxes and try mine when the m8 returns from its holiday. even without testing, i remain a big fan of this lens.
cheers
rick
Thanks Rick
Thanks Rick
Will look forward to your results. Have a great holiday!
cheers
rick
Ok, so who put the "110 cm" tag on the cheese-it box and the camera focus at 150 cm ? What does it say about this "test"? ?
lol
lol
Just checking to see if you folks are reading the comments notes, and not just jumping into pixel peeps!!
