Fomadon LQN + HP5+ pushing questions
einszwei7
5:15 AM
i just bought a bottle of Fomadon LQN because it's cheap and fotoimpex describes it as "Equalizing-Speed enhancing". so i want to try pushing hp5+ to maybe 1600 and 800.
I can only find dev-times for 400 with fomadon lqn, has anyone used this developer for pushing before? Can i just add 50% to the dev-time for a 1-Stop push, 125% for a 2 stop push etc?
Would love to hear from your experience
Cheers
I am still looking for an answer in case anyone has tried pushing with fomadon lqn, i couldnt find any info on it so far.
i haven't gotten to try it myself so far, i might just try in the next 2 weeks if noone answers.
It would be interesting to hear people's results. I don't know that developer. I know when I compared results with Tri-X and HP5 using D76, I thought Tri-X was much better behaved when pushing to even ASA 800, much less 1600. That was over 40 years ago, so YMMV.
Someone here https://www.photrio.com/forum/threads/is-fomadon-p-equivalent-to-d-76.33805/ claims it's similar to Ilfosol 3. See if you can find some tables that have the same films and check if the times are the same to confirm?
thanks for the link you sent. although i didn't find the information in your link a quick google search suggested they indeed have similar ingredients an pH values.
The times suggested on at massive dev chart are very different from ilfosol 3 though, sometimes fomadon 1+10 has twice the time ilfosol 1+9 has
So in case anyone is interested: i shot some test shots with hp5 rated at 1600 iso as a test roll with my newly aquired Point and Shoot (Canon Prima Mini 2).
Probably not optimal testing conditions but i was positive the camera is in working condition because it was pretty much mint condition.
I developed in Fomadon LQN 1+9 at room temp for 22 minutes, 10 seconds of agitation every minute, washed, then fixed in adofix for ~5 minutes.
These are straight scans from my Plustek Opticfilm 8100, altough i did significantly lower the contrast in the picture of my cat, because it was basically black for the background and white for the cat, altough his face/throat are snow-white an where lit by daylight coming in from the window.
What did i learn?
-My new P&S has trouble finding focus
-Developing time seems to be ok, contrast is very high and not a lot of shadow detail is preserved.
-Grain is not too big imo
- i definitely need to do this again with my bessa and try to actually take some good photos rather than random snapshots on my commute.
https://abload.de/img/untitled2lyj3k.jpg
https://abload.de/img/untitled3j4j47.jpg
https://abload.de/img/untitled4zmjcf.jpg
https://abload.de/img/untitled5wgjkk.jpg
https://abload.de/img/untitledffkgu.jpg
