formatting sd cards
emraphoto
10:38 AM
hi there... wen't on a bit of a trip and brought along the r-d1s. unfortuneatly i forgot my usual pack of sd cards... i tried a generic wal mart 512 mg sd card and mt r-d1s won't format? it won't even rcognize it? never had prob's before with sandisk 2 gb's? any hints?
Format cards
Format cards
They should work using 1 Gb Scandisk Ultra in mine working fine, but it won't recognize anything bigger than 2 gigs? I also have a 4 gig card have not tried that one yet?
Go into your manual it will tell you the camera will not work with cards over 2 gigs!
Check the write protect tab isn't set to protect.
"They should work using 1 Gb Scandisk Ultra in mine working fine, but it won't recognize anything bigger than 2 gigs? I also have a 4 gig card have not tried that one yet?
Go into your manual it will tell you the camera will not work with cards over 2 gigs!"
it's a 512 mg card... i USUALLY use a 2 gb. it's a 512 mg that's the problem...
If the card has no formatting at all, it may have to be formatted via computer first. Then format it again in the camera. As Gid said, be sure the write protect tab has not been switched to on.
O.C.
