Found this on Adobe's site where they talk about their App "PhotoSmith" which syncs with Lightroom and is made for organizing and light editing of images on the iPad.
"Leica RAW
At this time, we do not recommend using Photosmith (or the iPad) with Leica DNG raw files unless you shoot RAW+JPG. Apple’s support for Leica’s DNG format is very weak and in most cases will display only a 320×216 thumbnail as it’s largest size. This is because the DNG format that Leica shoots doesn’t contain as much information as other raw formats and in most cases, not enough for the iPad to be able to generate a full screen preview. Since Photosmith relies on Apple’s RAW handling, we are limited by Apple’s support.
However, if you shoot RAW+JPG then we combine both files together to extract all the information we need to display a large preview (up to the max size of the JPG you shoot). In all cases, even if you can’t see a large preview, you can still rate, tag, keyword, etc. and when you sync with LR we’ll sync all the files over including the DNGs."
Best,
-Tim
"Leica RAW
Best,
-Tim
