FP4+ only. How many ways to shoot &process
davidnewtonguitars
Family Snaps
7:16 PM
I started this so it could be a new thread on this film only. I shoot FP4+ only, normally at iso 50, and develop only in D76.
How many ways are there to shoot and process this great film?
Roughly, an infinite number. Shoot at EIs from 25 to 500; use a spot meter, an incident meter, or a broad-area reflected meter. Use any one of probably 50 developers (modifiable to maybe 500) and process at anything from 18 to 24 degrees C, 65-7F for anything from 2 minutes to 2 hours (or more).
Ok, not how MANY ways, but your personal way to get what you like. If someone tells, and shows, how he gets super fine grain with super wide tonal range, we could stop there, but someone else may like to see something more dramatic.
Connels Sign Makina IIIR 100mm F4 by Nokton48, on Flickr
FP4+ in Plaubel Makina IIIR, 100mm F4.2 Plaubel Anticomar (the sharp Plaubel lens!) Freestyle Legacy Mic-X straight developer, replenished. ISO about 50, 1/50 @ F16 in key day bright sun. This developer, if replenished frequently (and not allowed to oxidize due to lack of use) will last for YEARS. My last gallon lasted FIVE years and it gets better as it "seasons".
Why shot it on ISO50 if it is not discount film?
Since it is slow film and do it in Rodinal.
scan
print
I've had a lot of problems with excessive contrast with this film. Tamed a bit with dilute HC-110 - While the Massive Developing Chart says 7-9 minutes for dilution B (1:31), I've been using 1:74 dilution for 7 minutes. Even with this I've often have to print with a Grade 1 filter.
Do you also shoot it below box speed? Or at box speed?
I don't know how much FP4 you have laying around, but my suggestion would be to make your life simpler and better by shooting some Tri-X and developing it in your D76 full strength. But, that's a 400 speed film you say? Not really. I and most people shoot it at 200-250, and the one time I shot it at 100 and developed it normally it still looked pretty darned good.
That film and developer combination is very, very hard to beat, and you get beautiful tonality. It's essentially foolproof. You can meter it all over the place and still get great negs.
