prontor svWhat is the make of that shutter? Doesn't look like a Prontor (for which I'm trying to figure out a similar problem myself) or a Compur.
Funny -- that doesn't look anything like the Prontor SV I am dealing with. The only thing that's the same is the cocking lever. Mine is off a Vito II, so mid-50s vintage. Your Solida must be from around the same time?prontor sv
I think it is later than the one you are familiar with as it appears to have the dreaded light value system and a modern speed sequence.Funny -- that doesn't look anything like the Prontor SV I am dealing with. The only thing that's the same is the cocking lever. Mine is off a Vito II, so mid-50s vintage. Your Solida must be from around the same time?
On the SVS, the self-timer is where the left hand red ring is above. I'm guessing the right hand one marks the slow speed escapement?That's not my shutter, but -- check those for what exactly? Unclear what those areas/parts do. (Trying to learn for myself.)
I never had the shutter apart till nowThat's definitely not right. Just wondering... blades aren't upside down, are they?
A previous owner?I never had the shutter apart till now
