Darthfeeble
But you can call me Steve
- Local time
- 12:39 PM
- Joined
- Sep 25, 2008
- Messages
- 2,705
- Location
- Northern California Sierra Foothills
I've scanned 120 with an epson v600 with very satisfactory results.
I know that you can get "satisfactory" results, but how does it compare to an original full frame digital image. I'm thinking of print sizes up to 16x20 or perhaps 20x30.
My takeaway here is that everyone has their own preferences, and I won't learn my own unless I start somewhere. I want a 35mm rangefinder and a MF camera. I'll pick one and, no matter what, will learn a lot. That's very encouraging. Thanks for the great advice, everyone!
I didn't want to get too far in the weeds with the comparison. The reason I asked is that the OP is going to be scanning his images, and I was interested in whether by digitizing his MF negatives, he was giving up the advantages of MF film over full frame digital. I was looking for a general answer. I know I was disappointed with the quality of 6x prints from V700 scans of 35mm B&W film, for example. A 6x print of a 6x6 negative is roughly 13.5" square. If I were shooting more MF film, I would want a dedicated MF film scanner, which is not inexpensive. Using MF film is just one piece of the equation.An "original full frame digital image" from what camera and lens? What format medium format are you referring two, what film, processed how, etc etc...? And what kind of skills have you got with film scanning and digital image rendering from film scans?
I'm trying to indicate that there are a whole lot of variables to nail down before attempting to make such a comparison. After 23+ years of scanning film formats from Minox to 4x5 with a huge range of scanners, and learning how to render them, I'd say that the difference in "quality" is purely an aesthetic one. A film negative has a different look and feel than a digital capture, quite independent of its "quality", so a well captured and rendered FF exposure can compete head to head with a well captured, scanned, and rendered MF image depending on what you're looking to compare them by.
Done right, you should be able to hang same size prints from either without anyone knowing which is which. Some people will assert that "they can always tell" but in all the time I've been hanging shows and selling prints, what camera and capture medium was used has never been an issue that I spent any time explaining.
Except on photographic equipment forums like this one, of course. 😀
Everything he said is correct....
I feel a bit guilty asking for more feedback before I've offered anything constructive back to the community, but since the brains in this forum are second to none, I figured what the heck.
Yesterday a photographer friend recommended that, as I jump into film from digital, I skip over 35mm and go straight to medium format.
Here is his reasoning:Note that I am not printing (as of yet), but am enamored of the special “something” that I see in 6x7 negatives, and even halfway competent scans.
- The digital camera that I have (X100F) is extremely flexible and capable in a wide variety of situations, and so it works wonderfully as a snapshot and travel camera for my purposes. He thinks I will be disappointed in a 35mm camera because it will be much less flexible and the results will look too similar to my little digital rangefinder.
- He says that if I want to be wowed by my film pictures, it’s best to jump to a format that is less similar, ie, 645 or 6x7, and use something like a Mamiya rangefinder or a Plaubel Makina.
- If I want to make myself slow down and pay more attention to the process of taking a picture, that can be done with a medium format camera just as well as with a 35mm, or perhaps better since it will take fewer shots per roll.
- I don’t have access to a color dark room (yet), and his experience says that MF is easier to work with on a scanner.
So what do you think of his recommendation? Does it make sense to jump into film photography and supplement a digital with a medium format camera?
I believe I’ve made up my mind, but it was an intriguing idea I've not seen promoted elsewhere, and I’d love to hear what everyone else thinks.
That's the kind of information I was looking for. Thanks.That begs the question: "What do you perceive to be the advantages of MF film over (a modern) FF digital capture?"
Flatbed scanners are not the best film scanners. I had the V700 and found it to be only so-so with 35mm film. It was only able to achieve between 2300 and 2900 real PPI, so the output file at best @2900 is about an 11 Mpixel image with all the issues of scanning film to deal with. A dedicated Nikon Coolscan V ED produces far better output with a true 4000 ppi.
On the other hand, switch to 6x6 and that same V700 at 2900 ppi produces a 41 Mpixel image that's got much more to work with. I've produced very satisfying 20x20 prints from such scans, and larger is easy if you use some sizing tricks.
My Leica SL or M-D are 24 Mpixel, FF cameras. Without the noise of film emulsion and grain, I can make good clean prints at lower printing PPI and achieve very very clean 17x25 printed area photos from them. With the same tricks as above, I can get up to about half again that size.
So if its print size you're after, it's pretty much a toss up between MF film and a 24mpixel or better FF camera, as long as your lenses are good and the image you're printing is good calibre. Other qualities of a print are more an aesthetic choice, as I said before.
For 13x13 sized prints from MF negatives, I eschew the scanner entirely and use a copy camera technique to capture the 6x6 negative. This nets a max 16 MPixel image from the SL which prints beautifully at 300 ppi to 13x13 size. Faster, cleaner, and more manipulable ... and all the character of the original 6x6 camera to boot if you do it right. 🙂
