FSU lens and RF adjustment on Canon P
02Pilot
Malcontent
9:37 PM
NY, USA
I recently purchased a Canon P body. My intent is to use my Jupiter-12 and Jupiter-8 on it. While checking and adjusting the RF calibration I found that it is not possible to have both close (1m) and infinity settings on the RF correct; with close focus set properly, the RF image goes beyond the VF image at infinity. The variation is similar with both lenses, so this appears a function of either FSU/Leica incompatibility or the RF cam follower eccentric requiring adjustment. I do not have a Leica-standard lens with which to check at the moment, so I do not know which of these possibilities it is.
My thinking is that if the problem does come down to FSU/Leica compatibility (as I suspect it might), I should keep the RF adjusted for close focus, accepting the fact that while the RF may be slightly off at longer distances, this is unlikely to have a practical effect on image focus except possibly on the Jupiter-8 when shooting wide open at distant subjects. It seems to me that DOF should take care of the RF/lens inconsistency in most cases, while I should be able to accurately focus on close subjects.
Just looking for a check here to determine the validity of my process. Thanks.
Makes sense to me. Scale focus is easy beyond 5m or so.
It could sill be annoying to constantly shift between the two different focussing methods, and you would have a "gray area" around 2m where neither of them would work at their best.
So if you plan to stay true to russian lenses for a while, i would still
advise to get the camera's rf cam length adjusted. I did, and haven't had a chance to regret it yet. Because I only have russian lenes for it.
It's not that I have any particular attachment to FSU lenses over others, it's simply that the LTM lenses I have are all FSU at this point. I'm looking into getting a couple of longer focal length lenses which would not be FSU, as my understanding is that the incompatibility becomes more problematic at longer focal lengths, but I simply cannot justify the usual prices of 50 and 35 LTM lenses that precisely meet the Leica standard when I have the Jupiters which I know work well. Just trying to get the most out of what I have.
