FSU lenses compared to Leica - please discuss
Florian1234
it's just hide and seek
11:07 PM
somewhere in the middle of Germany
Hello,
I just had a discussion with a fellow photographer. She owns a DSLR and a film-SLR and said the real Leica lenses would be way better than the FSU copies.
To what exstand is this right? I mean, are the real ones way more sharp? Do they focus better?
I tried to explain to her that I want to buy a set of filters for my camera (Fed-2) and she did not understand because it would just be wasted money.🙄
Please give me some comments on this, guys. 😀
FSU lenses for RF cameras are copies of pre-WW2 Zeiss designs (not Leica) with extremely wobbly quality control. Current Leica designs are much more modern with better glasses, computer-aided design and much better quality control.
This is absolutely nothing to do with buying filters so I don't quite understand her point.
Thanks Roger,
neither do I understand her point. But maybe that's just looking down from her SLR perspective. Not that I want to start a basic discussion here - Lord, no.
Her "point" was basically "don't waste money on that stuff". But it takes cool photos, as you know.
The real Leica lenses, as I understand it, are not "way sharper". Russian lenses are slated largely because they were cheap (subsidised), and hence carry no snob value. Don't confuse cheap with poor, it's not always the case. Your FED 2 has (presumably) an Industar 26; it'd be hard to find a significantly sharper lens.
Sounds to me like she's a bit of a snob, I wouldn't worry over it. If you want to buy a set of filters, go ahead since it's your money that will be "wasted" not hers. Whom will it make happy? Ignore her and indulge as you see fit, it's not for others to criticise your choice in such a matter.
One other thing to consider: the photographer makes the photo as much as any equipment does. Even the lowest quality camera can be used to make interesting pictures. Your FED 2, however, isn't in the "low quality" category.
Well Florian,
Leica lenses are better than the old FSU glass, but I doubt that they are 20 or 30 times better.
And also, we are talking about FSU lenses minimum 20 years old - if not older.
In my opinion, a '60ies Jupiter-8 or Industar 61 holds up quite well against a '50/'60ies Leica lens and all of them still can be very fine performers, if maintained and adjusted properly!
It is most probably a mix of both wobbly QC (as Roger mentioned) and lack of maintenance and adjustment if a Russian lens does not perform well.
Just don't believe your fellow photographer! ;-)
Best regards,
Uwe
Florian1234 said:
Thanks Roger,
Ask her a simple question: In 20 years time, will her all-singing, all-dancing DSLR still be working? Your FED is already older than that. If it is working, will it still be in use, or will it be a piece of worthless, outdated rubbish? You could also ask how good the pictures are when she's miles from anywhere and the batteries poop out...
Or you could ignore the snobbery and carry on enjoying the FED.
Florian1234 said:
Thanks Roger,
Dear Florian,
Exactly. If you like the results, they're great lenses -- and filters make just as much difference as with Leica lenses.
I had a 50/2 once that was assembled so badly you could hear and see one of the elements flopping too and fro inside the cell. It still worked, surprisingly well.
They are not very sharp, because the purpose of the Sonnar design (50/1.5, 50/2, 85/2) was to maximize contrast, even at the expense of resolution -- and, as I say, they are 70-year-old designs, and it would be a bit odd if they were as good as today's lenses. The contemporary Leica designs had more resolution and less contrast. And they're not as good as later designs either...
In other words, don't let the snobs persuade you they're useless -- but don't let the reverse snobs persuade you that they are superb lenses, either. If they were put together right (many weren't) they were very good lenses for their day, but their day was a long time ago. The only one I'd call good was the 135/4; the worst, by a long chalk, was the 20/4. But both the 85/2 and 50/2 are great, if you like the look.
First generation Summilux is not a better lens than Jupiter-3, and I've got negs from both. Then there is collapsible Summicron, which I never used but nearly all wide-open examples posted are underwhelming.
These are 1950s lenses, from 1960 and on there is clear improvement.
Don't worry about the quality of images from your FSU lenses Florian.
Many Leica owners use Jupiter and Industar lenses.
I'm one of them - two of my favourite lenses are my Jupiter-8 50/2 and my Industar 50/3.5, and I use both of them on my M6. (I think I paid about $20 for the J-8, and the Industar came with a Zorki-6 that cost me about $30).
Just use the lenses you enjoy using and which give you results you like.
Maybe a good time for me to interject this.
I`ve been shooting FSU`s for a few months now and have been thrilled with the quality of pictures and just as thrilled shooting with my Kievs, Zorki`s and the Fed 2.equipped with Soviet lenses.
So much that I decided to step up to the more costly world of Leica because I felt the overall experience just had to be even better than with a FSU so I bought a nice looking recently CLA`d Leica IIIf. (not cheap)
Yesterday I shot a test roll of film with it and the results were really very good using with my Jupiter 8 , Industar 22, and Fed 50 lenses all performed admirably. Detail was excellent as usual but certainly not any better than pictures from any of these lenses used with my FSU`s. Obviously the lenses will produce pretty much the same pictures regardless of what brand camera they are attached to.
I was however quite dissaponted in the camera itself. Mainly with the VF and the RF focussing itself. Although the VF glass was clean and clear and the RF accurate , my Zorki 2C is better , especially in the darker situations . The Barnack Leicas are absolutely no match for my Kievs . I can see why Contax was such tough competition for Leica at that time but that`s for another time and story.
Not having any Leica glass I am not qualified to comment on a comparison . I would expect Leica glass to be among the best since you have to spend so much hard earned cash to own one.
That said , I know perfectly well what a sharp picture looks like and I can recognize the effects of distortion, flare and contrast. My experience with the many FSU lenses I have clearly shows me they are undoubtedly one of the best bargains (if not the best) that can be found on the entire Ebay scene.
For her to imply they are a waste of money is nothing more than ignorance.
John
Florian, One of my favorite lens has become the black Industar 61 off of my Fed5. It's now on my Bessa R and gets more use as of late than my 35/2.5 color skopar or my elmar 50/3.5. Don't pay any attention to others, just shoot and be happy.
My Industar 61L/D will have to wait until my Nikon RF test of Ten 50mm lenses on the Nikon SP.
It's a great lens. I modified it for the Nikon Mount.
Pitxu said:
:bang::bang::bang:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=150211336737
On topic: The best FSU lenses approach sharpness and resolution of some Leica lenses of the mandler era. But colour and flare resistance of the Leica lenses has always ben one step ahead of what I see from the FSU gear. There may be exceptions but roundabout I think that is all there is.
Stefan
