Are you looking on US eBay???
Wonderful pics,guys😀..well I've just seen a fuji gw 670 III ?????what's it? same focal than gw690?I couldn't find any on ebay...should I consider it?
@ C R I've bought a VC bubble level that is great to use🙄.......great pics
I count at least a half dozen in various form and model ... G690, GW690, plus GW690II and GW690III. Yes, there is a 6X7 and was in all those models. There is also a GW680 in both the II and III models which was a home market (Japan). It's starting to show up on the US site frequently. It is 6X9, and NO, I am not confusing it with the GX 680, which is a full modular system camera. I REPEAT, DO NOT MAKE YOU'RE OWN ASSUMPTIONS ABOUT THE CATEGORY AN ITEM SHOULD BE LOCATED IN BY YOUR THINKING! That's the best way to miss the better deals. Search very few key words in All Categories. Also search intentionally mis-spelled names and models. eBay does not edit, does not spell check, and does not baby sit people on category placement. If someone puts an item in the wrong category, eBay could care less. In fact many people do make determinations about better categories to sell in than would seem logical and often do, intentionally, use categories that bring better results. I do it all the time by researching closed items and finding out where the items bring the best results.
I have a search saved as Fuji in Medium Format.
Search in all categories for Fuji 690. You're sure to find at least one. Then look at the categories and go back about two categories until you find Medium Format, (not by mfr). Then do a search on Fuji. You should get around 100 items to wander through.
Or try this link, which is my search string for best number of Fuji in Medium Format:
http://photography.shop.ebay.com/Medium-Format-/710/i.html?_nkw=fuji&_armrs=1&_dmd=1&_from=R2&_ipg=50&_pcats=15230%2C625&_sop=1
That will pick up all the Fuji cameras in Medium Format Film cameras on the US eBay site.
There are consistently at least 6 to 10 of the big rangefinders in various models on the eBay site. One very good seller, who often has two or three is a user named fotofila
These camera's are neither rare or hard to find if you are seriously looking for one. Prices range all over the place, starting at around $500. Occasionally less, and going up to around $1000. There are some truly unrealistic sellers over $1000 who claim to have exceptional low count boxed like new and are way out of line on price. I've purchased (and sold) exceptional, low count, boxed and like new examples for well under $1000.
The bottom line is that, while the model designations are confusing, there are quite commonly found three formats and two lens variations.
Formats are:
6X7
6X8 (limited in number in the GW, NOT the GX)
6X9
Lenses are interchangeable on the G series, and fixed after the GW
65mm (harder to find, but found in the interchangeable and fixed lens later models)
100 (only on the interchangeable early models)
90 where found as the longer lens on the fixed lens models
G most often early interchangeable
GW means the camera is a long lens - 90 fixed
GSW means the camera is a wide angle 65 fixed
Early models were also made under the longer Fujica name, so a G690 or G690bl will often be listed as a Fujica.
And even with all that, I haven't covered all the misunderstood ways people list the cameras, nor the limitations of the eBay search engines.
You have to be creative and persistent with changing spaces in names and models on searching eBay or you will never find ALL the variations of screwed up ways the listings are put on the system. Furthermore, if you don't get creative on the searching, you will likely bypass the good deals, because that means that people are not finding the deals and therefore, there is no bidding on poorly titled listings.
eBay is very confusing and tricky for many people. Try to change your searches around with regard to spacing and spelling, and don't use too many search words to begin a search. Also start your searches in all categories. Good deals on eBay are quite often Mis-Categorized.
Hope this helps
