Fuji GSW690III w/65mm Lens, Need a Center filter?
bherman
bherman
7:16 AM
Shrewsbury, MA
I have a Fuji GSW690III camera with a 65mm F/5.6 EBC Lens. I've heard from some users that it is recommended that you get a Center Filter to address light fall-off on this wideangle lens.
Has anyone run into this or is this necessary?
Thanks
Brad
What?!
What?!
No.
I never observed falloff from mine that would merit such an expensive fix. In fact, I don't recall ever seeing falloff at all.
But think of it this way: outdoors, you're probably never shooting wide open, and indoors, you'd never notice.
Light fall off with wide-angles
"Officially" a real wide-angle lens should have light fall-off according to the cos4 rule, e.g. with a 90 degree angle you would have a two stop fall-off.
Most wide-angles use a trick against this (like the Zeiss Biogon in the Hass SWC), by introducing some residual coma. This brings back fall-off to less than a stop.
If you want to know exactly how it works, google for "Slussarev principle".
BTW: retrofocus wide-angles do not have this problem, or in a far lesser degree, because the rays do not hit the film at such extreme angles.
