Fuji GW690II Loose Shutter Speed Ring
noah b
3:22 PM
I recently picked up a Fuji GW690II and the shutter speed ring is a little loose. The shutter works perfectly, and the aperture ring feels normal. But the shutter speed ring is pretty loose. I can still feel the click, but it moves so easily to the next speed. It gets a little better once you get up to 1/125th, but below that it's loose. Doe anyone have any info on how to fix this? If it's pretty simple I can probably do it myself. Any help is appreciated, thanks!
There is a Fuji GW690 group on Facebook, and Frank Marshman (a pretty reputable Fuji tech) often chimes in there. You may want to ask your question in that group. Good luck!
