Sid836
I have bought an Elmar 50mm 2.8 for my Leica M4-P (M mount) and I am thinking using it with an adapter on my X-Pro1.
Would it impose any danger to the sensor when collapsed? I could have it extended all the time, but it is always nice to keep things tidy. Also, using an M mount adapter will I be able to use lenses with that focusing tab that locks at infinity?
harpofreely
I've collapsed the following without any issues on my X-E1 & X-E2:
Elmar 50mm f3.5
Summar 50mm f2
Summitar 50mm f2
Summicron 50mm f2
Elmar 90mm f4
My adapter is a cheap off-brand M to XF; I add an equally cheap screwmount to M adapter as needed.
When I look at the sensor on those bodies, I can see that it is surrounded by a baffle that would not allow the lens "stem" to contact the sensor, as the remaining opening is too small. However, I have never had the lenses contact that baffle either.
As always, YMMV.
Elmar 50mm f3.5
Summar 50mm f2
Summitar 50mm f2
Summicron 50mm f2
Elmar 90mm f4
As always, YMMV.
Dante_Stella
Rex canum cattorumque
It's not a great idea to collapse lenses because the barrels tend to bring dust from the outside into the sensor chamber. On an X camera, the shutter is always open when the camera is idle, so it's not hard for the dust to quickly find a new home.
D
D
