Fuji x100 w/Ricoh GW-4 (26mm FOV)
shawn
6:01 AM
The Ricoh GW-4 has a 49mm thread on it and seems to work well on the x100. No vignetting (it was built for the wider GR3) and it gives a little bit wider FOV than the Fuji teleconverter, just under 26mm FOV. It blocks a lot of the optical viewfinder but since the framelines are wrong anyway the EVF makes more sense.
One thing to watch out for is the threading on the adapter is deep to activate a switch on the Ricoh.
On the x100 this works fine. But I have a IR Chrome filter on my full spectrum x100 and that filter doesn't have a lot of threads available. The GW-4 wouldn't attach to the IR Chrome filter. I bought a cheap 49mm UV filter and took the glass out as a spacer.
With the spacer on the IR Chrome filter the GW-4 attaches fine.
I leave the spacer on all the time. It brings the lens cap just about even with the hood that is normally on the camera.
Shawn
i'm about to get back my X100F from Kolari with the full-spectrum conversion and the IR filter. are you getting the results you expected? i hope that it produces an IR Ektachome look.
I just got the filter a week or two ago but like it so far. Straight out the camera isn't quite what I was hoping for (more orange than red, tweaking WB more might fix this) but I have a preset in LR that gives me what I want to the RAWs with one click. It changes the foliage to more red and moves the sky from cyan back toward blue. I never shot IR Ektachrome so not sure how close it is to that though.
This is the RAW with no additional processing:
with my preset
Shawn
