burancap
Following is the X100S finder. Skip to 1:12 if you are as impatient as some of these posts...
http://youtu.be/H6a7_NNP-t8
I have tried the X100s split-image focusing a couple of times, but must admit I concentrated on evaluating the easiness and speed of acquiring focus. How usable is it in judging the degree (distance) of being out of focus? It looks very messy when the deviation is larger, but should do quite well at least when being close to focus, am I right? Just how close is close?
Sigh. No that's not it. You can mirror in the digital split screen rangefinder of the X100S.
It's funny that the most people with negative opinions on here seem to have never even touched a X100(S)
What negative opinions?
And why would I ask questions if I already have a Fuji X100s.
Rather than sighing, why don't you educate me on what is that split rangefinder thing in these cameras. Are they similar to the ones we'd find in a film rangefinder or not?
Hi all,
The new digital Rangefinder function mirrored in the optical viewfinder of the Fuji X100T gives the camera pretty much full manual focus rangefinder capabilities.
So is the X100T considered a rangefinder or not?
What's your opinion?
I understand when similar aids are implemented in system cameras where one slaps on manual focus lens. But now tell when one would reject to rely on AF or simply dialing in distance in X100? Is this a practical mean to work around underdeveloped AF or a fifth wheel mounted in back of car to look like English three-wheeler?
(a) One uses MF in situations where MF is, for whatever reason, preferred. One uses AF in situations hwere AF is, for whatever reason, preferred.
(b) No.
Reading back through the thread, it appears that for many this definition renders "rangefinder" virtually meaningless, as it broadens the definition to include all AF cameras and manual-focus SLRs. 😱 And it leaves out "direct view" guess-focus cameras, which many would like to include in "RF".Put the question in a simpler format.
Does it calculate the "range" (distance) to the subject. YES! NO!... you decide.
Simpler yet.
Does it find the range?
Will, yes I think the "split rangefinder thing" is similar.
But I will not educate you on it. You have to do that yourself. With well over 8000 posts on this forum, I assume you are mildly interested in the subject 😉
...But now tell when one would reject to rely on AF or simply dialing in distance in X100? Is this a practical mean to work around underdeveloped AF or a fifth wheel mounted in back of car to look like English three-wheeler?
Or thought it meaningless? All cameras with a distance scale on the lens can be considered rangefinders by your definition. Plus any that use an active or phase detection AF system. Doesn't leave many out!
The question being posed is whether the new X100T focussing mode makes it a rangefinder. I say about as much as a CLE has a metered manual mode. In other words, no, but perhaps near enough for nearly all purposes.
Dear John,
A Pentax with a separate rangefinder? I've never encountered that one, though of course the early Alpa rangefinder/reflex cameras are well known. I think the Model 7 with the vertical RF was the last.
