colker
I find washing the fim to be the most delicate part of the proccess. Invest on a washing tank so that all rolls have loadas of water coming thru. Make sure of a detergent bath in the end so you don´t have water marks and hang the film to dry in a dust free area. Everything else is agitation..
Next on my thoughts is a clean fixer. A well fixed negative is a must.
I have always worked w/ stainless tanks and spirals. I find it a cleaner solution than plastic but you need a light tight darkroom to swap chemicals. Once you master the steel spiral you are a Jedi.
