rodinal
film user
The list in the M9 does not contain all the lenses that have a 6-bit code. For example: if you have the Zeiss 18mm, there is no chance to select the Leica 18mm. Luckily I have the Leica 18mm with the 6-bit code. I bet there are more examples for Leica lenses that are not in the list.
Interesting.
The Leica 18mm is not on the Leica list of lenses able to be coded.
This may suggest there is no dedicated code for that lens (although at least one web page (cannot insert link to it) actually lists a code for the 18mm).
Or, as this lens is a relatively new (2008) addition to the Leica stable, may be all 18mm specimens are born already coded. But, if this was the case, the lens should appear in the camera list. Is the firmware of your M9 up to date ?
Just out of curiosity, When you mount the Leica 18mm on your M9, does she report the mounted lens correctly?
