Glossy BP Summaron 3.5 Goggles - rare?
flagellum
7:50 PM
Hi all,
Recently got my first Leica (M3 SS), which came with a goggled 35mm f3.5 Summaron lens. I got to looking around for info about the lens online, and noticed something peculiar - virtually all of the photos online show the Summaron goggles as having a rougher, almost hammertone-esque texture. On my copy, however, the goggles are painted glossy black and are smooth to the touch/eye. The accents/rear of the goggles are chrome, so I don't think it's a black paint goggle that's been stuck on a chrome lens, and the paint job is smooth enough that it would have to be a very well-done customization if it was one.
The only example I've been able to find was attached to a prototype Summaron at a Westlicht auction. My lens serial number doesn't fall into any special range as far as I know (1360708) so I don't think I've struck gold in that regard.
Does anyone have any ideas as to what could be the case here? Additionally, does this increase the value of the lens at all?
I've attached a photo below, would love to hear your thoughts on my situation.
This is a normal M3-version (but can be used on all M-Leicas). On your lens the goggles can be removed (loosen the screw on top). Only the later ones, from 1958 or so, had the black crinckle-paint.
However, your version is not very common. Also, the f/3.5 Summaron is better than the f/2.8 version (above all in the corners).
In use, the goggles must be installed, if they are not, focusing will be incorrect.
Erik.
Thanks, Erik! Anyone have any idea whether this version would command a significant premium over the more common version? I'll probably keep the lens around, but if it's highly collectible or something I'd rather use it to fund something a bit faster than 3.5.
Sorry to resurrect this thread, but I found another peculiarity about this lens. I've noticed that the distance scale on the lens is marked in feet, not meters. Usual questions apply: is this particularly rare, and does it add any value to the lens?
In other news, I figured out that the glossy black paint summarons are rather rare! Only 764 were made in the first production run, dated to 1956. Exciting to have found a little gem like this 🙂
