If I remember correctly, the PX13 and PX625 are interchangeable but both are obsolete mercury cells. Maybe someone still has a stash. Batteries last a couple years in moderate use.
The way the manual dial 'saves' the reading handy.
My SuperPilot has been in use since the mid-70s and it's excellent within its limits. Response is typically Cds-slow at low light levels but it does have two sensitivity ranges.
If the needle hangs in the red zone to the left of the scale, you can thumb down the button on the left side to get it into low-light range.
It works by matching the circle with the pointer needle. With the white dome slid out of the way, it measures reflected light. The white dome slides over the cell for incident readings.
Adjust the ASA/ISO reading by sliding around the clear top cover disc. There is a trim pot on the bottom next to the battery cover to adjust the reading, but I think I've touched that twice since 1975.
www.craigcamera.com offers manuals, original or photocopied, at fairly stiff prices (I think).
