got my ql17g3 but with problems
Kat
5:57 AM
Philippines
After a long wait, my Canon QL17 GIII has finally arrived. However, it was an impulse buy and I did not get any information about the camera (ebay description was vague). My camera came with several problems--the shutter blades are stuck, the shutter button does not seem to trigger anything in the camera, and the advance lever advances endlessly even without the shutter being triggered. Thankfully, the meter appears to be working. I'll be sending it out to a repair person, as its ailments are beyond my rather limited capabilities.
Another problem that came with the camera is a missing part--the black plastic frame of the VF and the battery test buttons beside it. Does someone, by any chance, have one of these for parts? This is what the back of my camera looks like now...🙁
http://img.photobucket.com/albums/v196/nicoandfriends/Cameras/PICT6218.jpg
sounds exactly like mine, only difference ismy self timer is stuck in the on postition.
Honeslty i want to attempt to do it myself but im really scared to do it...
I got one of these -- wow, almost 2 years ago -- that had some similar problems. Yes, an ebay special.
With the help and encouragement here and some web surfing for similar problems, I was able to get it operating quite well, and I got my baptism by fire in camera repair in the process. 🙂
The stuck shutter came to life with just a wee bit of Ronsonol (lighter fluid, naptha) on a q-tip. There were some bent linkage parts in the f-stop and shutter speed dial assemblies, I guess the previous owner tried to force it. Once these were fixed, all of the shutter and winding stuff worked fine and (knocking on wood) have worked ever since.
The worst part of the whole ordeal was removing of the old grunged-out light seals. It was like removing tar.
If you don't want to try fixing it, Greyhoundman here used to fix them, but I heard he may not be doing it anymore. There are a couple others here who do it as well.
I'm not going to suggest you try fixing it if you're not comfortable, but I was able to do it and I am surely not an expert by any means. What it really takes is a steady hand and a lot of patience. The only oddball tool I needed was a lens spanner wrench, and I was able to get one from a co-worker. Since then I've actually seen these in stock on the pegboard rack at a local camera shop.
When I was fixing mine, some of the others here said they had "parts cameras" like that if I needed any odds and ends. Hopefully somebody will see your note and respond.
A good resource for finding hard to get things like this is the Classic Camera Repair Forum:
www.kyphoto.com/classics/
The people over there (like the people here 🙂 ) are good at responding to beginner questions.
Good luck, and do remember to post some photos when you get it working. It's really a very nice camera and I'm glad the people here talked me in to getting one. 🙂
Kat, Kitty or Doris--I respond to all.
Denise, Dee, Annie, or "Hey You" -- I respond to all. 🙂
hi annie ill go with that instead of hey you!
yeah i saw your previous threads about your progress on yours you made it seem so easy...
i think i still might do it myself, i just have to find a spanner wrench or a make my own with a needle nose pliers.
Hi Kat
Most of the Canon QL17g3's will have similar problems as yours unless thay have been serviced recently. These cameras are 25-35 years old and oil has gotten onto the shutter blades and caused them to stick....yours needs a good CLA and the plastic frame for the rear viewfinder. Many of the G3's have haze or fungus on the lens. I am located in USA and I service the Canon QL17 GIII... and have parts for it.... If interested in service or parts contact me.
winklee98
Thanks for all the suggestions. I was able to open up the front elements to work on a stuck shutter of my Minolta HiMatics, and the top plate of my Konica C35, but at the expense of scratching metal parts trying to open them with makeshift tools (can't afford a spanner). It's pretty cheap to get basic service here in the Philippines (about a little over $10USD), so I'll have it done by a repair guy.
Winklee, do you sell parts alone? It won't be cost-effective for me to ship the camera internationally...
You are indeed very lucky if you can find a skilled repair person who has those rates. Here in the States, when the meter starts running at a camera repair shop (if you can actually find one and if they know what a GIII is) it's typically several times that price.
You might check to see if anybody over there handles the Promaster line. I'm sure that was the brand name of the ones I've seen locally, which, IIRC, were US$20-ish.
Kat
Yes, I sell parts for the Canon QL17 GIII......I have most parts.......and you are needing the black plastic viewfinder frame & button for back of camera.
is there anything else....lens cap or filter ?
Contact DrHink2u@yahoo.com
