lawnpotter
Has any one ground down or taken off strap lugs? I am thinking of buying a cheap user Leica but I only want one strap for my wrist, and to prevent jacket holes I would like to remove one lug. Can this be done? Thanks
Without judgement, here is how you can DIY:
Take off the shell. Take off the cover. Take out the Lug. Cover the hole with scotch tape from the inside. Put "liquid weld" in the hole from the outside. Cut off the excess when dry. Ask Aki Asahi to cut you 4008 without the hole. Put everything back together.
(worked for me when taking self timer and frameline lever out).
With judgement: carry the Leica with wrist-strap on the other LUG for a while and the LUG will remove itself 🙂
Roland.
