screw loose
screw loose
the screw was hitting the shaft, I pulled the camera apart again and I can where it was scrapping.. all my screws got mixed up when I moved my work box, so I'm guessing a bit on what fits.
Anyway I reassembled without the blinds and the body cover goes on easily and the shutter works fine, so it's the blinds for sure..
when I initially pulled the front off I missed one screw in the blind to the right (as the camera faces you) so I bent the blind a bit.. I straightened it out, but now I'm starting to think I straightened it too much..
so before I put the blinds back in, I put a little curve in the blind, reassembled, used a short screw in that spot and the shutter fired fine, then I put the body cover on, it was a little tighter than without the blinds and the shutter sticks again...
soooo..
tomorrow (burnt out on this today) I will pull it apart again and try and put a little more curve in the blind, hopefully that will do it..
Thanks everyone for your help, if it wasn't for you guys, this would already be a "parts zorki" now I have hope that soon I will be posting images from camera
