tedwin
Not the Philips head one. I believe the Philips head one attaches the circuit board to the main body. The vertical adjustment screw is deeper in and further to the left (through the triangular opening) and is also a slot head screw but smaller than the horizontal adjustment one. Like I said in my previous message, unless you can repair fine Swiss watches or are absolutely sure of your skills, you are better off sending the camera to Zeiss for repair.
Maybe, to be sure I'm not too dim, I should quote both of you..
wizofz2k "In mine, the vertical adjust had a Philips (cross) head, while the big one for framing is the traditional slot head"
I appreciate that this is not a course, but you both clearly state that you know the adjustment for vertical alignment, through practice I have discovered that its not the one jjovin states it is, hence I wanted to double check with you.
So the vertical adjust Philips (cross) head screw that alters the vertical alignment in your camera, is that the black one towards the rear of the camera body through the triangular hole on the left under the hot shoe?
Clarification would be greatly appreciated.
Thanks again.
Ted.
P.S. for anybody reading this that thinks its too complicated to discuss on a forum, under the hotshoe there are a total of three screws visible, two flat head, one philips.
