One of the links I gave you mentioned methyl ethyl ketone. It is a bit nasty being inflammable and somewhat toxic but if all else fails its a well known industrial solventthat you should be able to get from a purveyor or industrial chemicals.Other industrial solvents like Xylene may work too - see information in the link below.
This following link is also useful:
http://www.recochem.com/products/paint_thinners_solvents/mekAmongst other things it says:
" MEK is a strong solvent and degreaser. It is excellent for dissolving resin, and adhesives and removing old finishes and contact cement. It can be used for cleaning fibreglass repair tools and for thinning fibreglass resins and is an excellent diluent for lacquer thinners."
Of acetone it also says: "Acetone is a relatively strong solvent and is excellent for dissolving two part epoxies before they set.........." This suggests it will not work so well when the epoxy has cured though I realize you seem to have had partial success.
