Hasselblad Superwide Supremewide SWC Lenshood and caps
Alpsman
11:35 AM
Austria
Made some lens hoods and caps for the Hasselblad Superwide, Supremewide or SWC with the old Compur lens with a M 67 thread.
With and without holes and slots, with and without the M 86 thread for a additional filter and caps with thread to screw in.
Happy printing ;-)
I like the hood, all the Chinese hoods on ebay have the wrong thread and only wind in half a turn. Shame I don't have a 3d printer...
Well - I've never tried a "chinese" lens hood. But the metric fine thread can be a . . . it have to be machined precisely. The pitch is 0,75 mm / 0,02952756" and if the tools are a little bit worn the profile of the thread does not form out nicely and - jammin.
At least my threads printed on my printer with my slicer with the filament I used are all "proofed" ;-)
Of course, I can print and send you one. But the postage for a package halfway around the world will cost more than if you had it printed online through a company.
Greetings from AUT to AUS: Dieter
You make me want to buy a 3D printer....
Be warned!
Once you have a printer and, ideally, can also draw with a 3D program, you'll always find something you were missing before but couldn't buy. Nothing vital, but just little helpers in everyday life.
Most of the things you find on my site
were created out of a specific need. Some were also created purely for fun.
I'm currently in the process of designing all Nikon lens hoods with the initial designation HN- or HS-. Not because I need one of them, but purely for the fun of designing.
I'm happy to accept suggestions and, if possible, I'll implement them.
I just downloaded the file with the vented option and will print it tonight.
Thanks
@Alpsman:
I printed (0.12mm layer height) it out and it came out fine on my Ender3 V2.
The threads sort of engaged on the lens but stayed on.
First: Thanks for your "make."
Then: I'm amazed that such fine threads can even be printed and work.
Consider this: The thread has a pitch of 0.75 mm / 0.02952756". The triangular profile of the thread is 0.64 mm / 0.02519685" wide at its widest point.
If you increase the diameter by just 0.1 mm / 0.00393701", it won't fit.
If the seams of the layers protrude only slightly, it won't fit. Depending on the material used, I sometimes have to rework the thread with a file.
But I've also printed working threads with a 0.5 mm / 0.019685" pitch.
The lowest layer height I can set on my Prusa Slicer is 0.07 mm / 0.002755906".
Even I have a variable layer height in the Prusa Slicer, so I can only print the thread with a low layer height and the rest with the normal layer height.
And it certainly makes a difference which printer, with which settings, and with which filament you print.
For example, I get different fits whether I print with PLA or PETG from Prusa or from Yajo.
But let's look on the bright side. If we didn't have the 3D printer, we would have to produce this part on the lathe and milling machine. That would be much more time-consuming and material-intensive ;-)
Greetings from rainy Austria: Dieter
