Out to Lunch
Interesting. I was blissfully unaware of the 're-enactment' scene. I've found some links to 'Confederates in the Attic' and will have a look. Thanks for sharing. Cheers, OtL
I'm interested in the design of the SWC Biogon and other attributes of the camera that lead to it having such a good reputation for low distortion.
Is distortion, or perceived distortion, reduced with the square format, as compared to the equivalent focal length on a 35mm rectangular photo, where distortion becomes more apparent at the periphery of the long side?
Or to ask a different way, is the SWC square image utilising the centre of the lens image circle where there is less distortion, whereas a rectangular format comes closer to the edge of the lens image circle where distortion may be greater?
Hope that makes sense.
There was an interesting discussion on RFF about this exact topic here, following a comment on the B&H blog.
It's certainly something I've noticed using the SWC/M, that the images look less distinctly 'ultra-wide' than when I use an equivalent wide angle on 35mm (eg. the Voigtlander 21/f4 on my M2).
My feeling is that it's a combination of things. First, the square format renders ultra-wides more neutrally than the 3:2 rectangle of 35mm because perspective distortion is identical along all axis, whereas 35mm is exaggerated along the long axis.
Second, the quality of the 38mm Biogon is such that there is very little sharpness or light fall-off away from the image centre. Likewise there's no perceptible radial distortion. Again, these qualities mean that the SWC renders very neutrally.
I don't think so. The SWC still (presumably) uses the whole image circle when shot with 6x6 back. If it were possible to shoot the 38mm Biogon with a 'native' 3:2 format, the diagonal of the negative would be the same.
Oh the boys over here are seriously into their Civil War re-enactments. They camp out in the most primitive conditions to endure what their forefathers went through. The battles are no small amateur event either, I have captured the fire blasting out of their canon and pistols.
Great weekend events and even having lived here since 1990 after leaving the Old Country as they call it, I always have the July 4th comments BLASTED at me…….the beer makes up for the insults and my wife is another consolation, more beautiful than any of theirs !!!!
Wow! Nick, this is outstanding! This should be on a book cover or a nature calendar or something like that.
Well done!
Mike
