Hasselblad SWC/M C T* lens thread size
ymc226
7:07 AM
...67mm
...67mm
i've had good luck with almost any 67mm filter on my swc/m. in fact, it helps the rubber lens cap stay on a bit more securely.
i bought a hood for it (somewhere on the 'net) and it turned out to be for the newer bayonet mount 38-60mm lenses...oops.
there is a hasselblad threaded version but i haven't chased one down yet. i wear a hat alot - either a cowboy or panama or floppy brim jungle hat - and carefully use it to shade the lens as needed. that can be tricky since the angle of view is soooooo wide :D
no experience with B+W brand hood you referenced...it may or may not cause any vignetting or intrusion into the aov.
breathe, relax and enjoy.
happy trails,
kenneth
