Vince Lupo
Whatever
An old (film) shot with the Hektor, scanned from the print.
I have one of these it is almost identical to the 85mm f2 Jupiter!Hello,
Another lens you might look for is the Dallmeyer 85mm F2 Dallac LTM which does turn up now and again at camera fairs in the UK.
I believe that it is a "Biotar" type lens design.
Well, I've found a Dallac LTM that sold on eBay a while ago, but that went for over EUR 2,000 😱
So, I guess I'm not getting that one!
Maybe I should look into the Jupiter 85/2.0...
After having had the heeby geebies for the Hektor for quite some time I had saved up some cash to try and secure one in the Westlicht auction in May, only to see the three lenses sold all rapidly passed my (limited) budget.
That was a cold shower.
BUT: Last week I bought a 1950 Jupiter-9 85/2.0.
It is new and unused. It comes with original case, front cap and rear cap. It has the original passport with it, stating is is collimated to 83,7mm.
Best of all, it has Carl Zeiss Jena Sonnar elements. They are stamped with a Zeiss serial number dating it to 1945.
Can't wait to shoot it. It should be collimated for Leica perfectly and will most likely be within original Zeiss factory specs. YAY!
Hello,
I'm looking into longer lenses with 'dreamlike' properties like the Hektor 73mm 1.9 , Thambar 90mm 2.2 or Summarex 85mm 1.5.
Many years ago we used a thin smear of petroleum jelly on a UV filter then later along came "orthoptic" adhesive patches used in the business of strengthening eye muscles. They attach to a filter or the lens and are available from opthalmic supply shops in varying strengths. Well worth a shot!
