Helloooo from Alaska!
Jim H.
9:11 AM
Soldotna Alaska
Hi all, I'm new to this forum and pretty new to RF photography. I had to find out what was so cool about RFs so on advise I got from another forum I bought a Bessa R and the VC 35/2.5 classic. I really like my new little outfit. I've only shot a few rolls through the camera and my results were first rate in my opinion. It takes a little getting used to not seeing through the lens. But I'm quite happy with the set up. Anyway, I'm glad I found this forum. Lets see if my picture posts.
Welcome, Jim! Gotta love those Bessas. Not only cost effective, they also have in-camera snow-removal processing. Where's the snow?? 😀
Be sure to sign up for the gallery too so you can post pics for us to see.
Gene
Thanks Gene. I just figure out how to use the gallery. There isn't much for snow in Alaska, at least were I live. We've been enjoying rain and wind for most of the winter. But it is January and the local lakes in my area are frozen finally. I went Ice fishing last weekend and there was about 14" of ice, just enough to drive on safely. What's a "peripatetic photographer"? Oh, I get it . Three words.
Welcome Jim,
You'll find alot of info here, looking forward to seeing some more pics of Alaska. I have hunted and fished outside of Prince of Wales, the Klawok (sp) area, and absolutley fell in love with the place, good to have you here!
Todd
Hi Jim
What you need to know is that when you down size and compress pictures to be posted on the web the loose detail or/ and contrast or/and tonal range
if you start out working with a picture in say 300 dpi 1600 pixels wide and you change the image size to 700 pixel in 72 dpi you need to sharpen the pictures and adjust the levels and then use the save for web funktion in photoshop. Using this function gives you the option of seing 4 versions and you can change the parameters so the work well on your image
The picture looks a bit dark and dull - if you need more work done in photoshop explore the history brush and layers functions the work wonders
I do like you picture though ! a feeling of solitude
ruben
Welcome, Jim.
I can't imagin how cold the place you are living in.
Ruben is right, your pic is suffering from shadow details lost. It is obvious at the right part of the tall trees. I am not sure which part go wrong, maybe scanning I guess.
But I do like the mood of your picture. It gives me cold, moderate wind and a bit lonely feeling. A sentimental picture.
Jochan
Thanks for the warm welcome everyone. Soldotna is about 60 miles south of Anchorage as the crow flies. We're located on the Kenai Peninsula. In fact the Kenai River flows right through town. The temperature outside when that picture was taken was in the low 20s. Clear skys usually mean cooler temps up here. Ruben, I don't have the full version of PS. Only the home addition. I follow what you're saying though. Practice, practice, practice.
Hello Jim! It is good to see another Voigtlander user! Do show us more of Alaska! 🙂
Doug said:
Hi, Cloudy! By common convention, I expect Jim means by "low 20s" somewhere between +20F and +25F, about -7C to -4C or so.
Hi, Doug!
Thanks a lot! 🙂
