Help! Delta 3200: Pull Processing
White "specks" and leaking bright light is normal for this film.
I was hoping the blacks would at least be black. Even white specks in the film in an area between frames are normal?
Here's another I like due to content, but technically, am not happy.
Here's a comparison between one with the M9 and the other with the Delta 3200.
No need to guess which was which. The M9 files weren't processed well, monitor was a bit off but oh well, they're already published, on to the next..
Thanks for reviewing and offering comments here, I appreciate the help!! 🙂
I've found with TMZ (very similar to Delta 3200 in my book) that I am tempted to look for more shadow detail in scanning than I do in the dark room. When I'm in the dark room, I set the exposure until I get a nice good black and go from there. While scanning, I look for the last little bit of details in the shadows. I've found that I can eke a bit more out of the shadows when scanning AT THE EXPENSE of solid blacks. I need to remind myself to not look for that last barely exposed tone, and set the black level a bit higher until I get a good black. When I do this, I find that I end up at almost the same range of tones as I get in dark room printing the same negative.
Long story short - raise your black levels a bit and the white specks will go away. The are in between frames is unexposed. It should be black. If you have a weak black there, you should raise the black level (adjust with curves or levels) until it's a good solid black.
Again, for me those results are beyond what I'm willing to put up with. Here are a few D3200 shots that made me decide not to shoot it again in favor of Neopan 1600 (most were pulled to 1600 I think):
Female Novice by NateVenture, on Flickr
Untitled by NateVenture, on Flickr
Tsukiji Fish Market by NateVenture, on Flickr
Neopan 1600:
I Ate this One by NateVenture, on Flickr
Neopan 400 @1600:
I send all my film off to NCPS for cheap developing and scanning, but when I asked what dev they use this is what they said, "Clayton Chemistry F76 which we believe is a derivative of D76."
Mister E - those are fantastic! Love the look of the Neopan 1600 in comparison.
The first with the candle is similar to much of what I was seeing.
Plan to zip through a fresh roll of Delta 3200 tonight, as well as some TriX 400 that I'll push to 1600 in Xtol to compare results.
I think the grain is from the NCPS scans. It's real sharpened and lumpy when I get scans of high ISO stuff from them. I love the scans for what they are, but I can only imagine what would it would do to traditional B&W film, especially high ISO. And that's ignoring how good/bad they might be at B&W developing.
Not trying to bad mouth them - it's where I send my color film and it's a great deal with great minilab-style scans. I just prefer to keep my B&W in house.
This is the kind of grain I get from a 4000dpi scan of TMZ:
My lab uses XTOL and say when I shoot it at 1600, they generally recommend still processing it as if it were at 3200. Only had one roll done by them, but it came out nice.
Nate, the grain in that 2nd shot is heavenly! That's perfect reason *to* shoot D3200P.
Your lab is correct. Ilford's times are *wrong*. Well known for a while now: if it's Delta 3200, develop for the next EI upwards. So if you shoot it at 1600, develop it for 3200 times, 3200, develop it for 6400 times.
It is what it is.
Tim, living in Japan I just don't have the time and space to deal with developing and then scanning black and white in house. I'm happy 99% of the time with what NCPS gives me. Perhaps I'm just not picky. I love developing, but not scanning. Scanning frustrates me 99% of the time.
Didn't end up shooting the 2 rolls (incl 1 expired) last weekend. Hopefully soon.
film base + Fog is not low with this film. I was getting around 0.3 but that could be partly caused by my fixer.
You will always get grain with D3200 its not a fine grain film. Using 18mins dev as I found for normal contrast makes things worse. It's really best in 120 format if grain is an issue for you. It's worse in microphen but if you want a true EI of 3200 then microphen is the only way to go and you just have to put up with the grain. DDX seems reluctant to go much faster than 1600.
I'd suggest you take speed down to 1250 for next roll and try Xtol. ( that is if you feel you were capturing plenty shadow when using EI 1600 )
Problem you have is that scanning will exagerate the grain.
Thanks. Starting to appreciating what "fog" means now.
I think the next time I will drop the EI to 1250 and develop in Xtol.
Tim - will raise the blacks a bit until I get a true black in the unexposed areas.
Working more with film again is helping the digital photography as well.
Nate - the images you posted in the 'all in the eyes' thread are all superb!
Hey I got you. I love NCPS. After seeing your results from them, I've been using them as my color lab. And thanks for telling me that the budget scans were the way to go over the enhanced scans. Great service for a great price.
It's just nice to note that better scanning results *are* possible if one does it in house. But it should be - there's no way I could turn out 36 scans for $5 of my time. It takes a lot more work and time at home. The two areas where NCPS (and most minilab-style scans) can be improved upon are in the highlights (things that look blown out really aren't) and grain. They do some noise reduction/sharpening combo that can give lumpy looking grain sometimes.
I've not sent any B&W to them, but I would think the grain issue, as well as not having full control over developing, could cause some problems. B&W grain is a touchy enough issue when it comes to scanning.
I still think you should give microphen a try at EI3200 just to see what this film is really about. You might be pleasantly surprised even with the grain. The benefit is the shadow separation you get in very low light (providing its in the subject).
Last time I checked microphen was a speed losing developer. Can't see how it could possibly pull more shadow detail than XTOL or DDX.
