Jonathan R
The front cell on the 40mm Tessar of my Rollei 35 is slightly loose (side-to-side play). This means that it loses its pre-set focus very easily, and I guess it can't help the optical performance either.
Does anyone know how to tighten this?
ZeissFan
I think if you remove the lens bezel (the lens nameplate), there should be two slotted posts that can be tightened.
I think this is the case, as it's been a while since I've had one of these lenses apart.
