Help identifying a 50 cron
W
Way
Guest
Saw a chrome 50 cron for sale. I think the serial number started with a 7 but I could be wrong. I forgot to check the filter size. No built in hood, and it had a focusing tab that could lock in place. You release it by pushing down on it. Scalloped focusing ring.
Anyone know the aprox. year and the type of image quality to expect from this lens (compared to the current 50 cron)? I'm always on the lookout for a nice 50!
The "focusing tab" sounds like an infinity lock indicative of the early rigid Summicron.
Does it look like this, from the KB Camera site:
S/N starting with a "7"? It could very well be a collapsible Summicron.
And yes, Wayne is right, "focusing tab" here really means infinity lock. It works like a focusing tab; but it isn't 😉
Also from KB Camera, M-mount Summicrons:
Type 1 Collapsible SN#1,124,000-1,548,000
Type 1 Rigid SN#1,303,000-2,260,000
The Leica 50mm F2 Summicron is heralded as the sharpest lens in the World. The Summicron was devleoped as a variation of the 50mm F2 Summitar in 1951. The optical configuration of the Summicron (7 elements in 6 groups) was similiar to the Summitar (7 elements in 4 groups), however, the Summicron utilized the new Leitz glass formulation incorporating the rare earth element Lanthunum. The early Summitar prototypes of the Summicron were marked with an * after the serial number.
The Summicron is a legend among optics. Approaching the theoretical limits of optical performance, the Summicron has been widely accepted among Professional photographers around the world. The design of this optic was so perfect that the Summicron is still manufactured today, and is still the benchmark to which all other lenses are judged.
The Summicron went into production in 1953, first in a screw mount and later in 1954 as a bayonet mount. There were four types of 50mm Summicron's produced. There is much debate as to which type is best, I am fairly positive that the differences in performance are slight, but the early 7 element Summicron has long been a favorite and thought among Professionals and Collectors alike to be the sharpest of the formulations. The later models had a slight increase in contrast over the Type 1. The Type 1 being ideal for Black & White and definately worth having in your camera bag. The build quality of the early units also seem more Robust in the authors opinion.
The early Summicrons came in both Collapsible and Rigid mounts. The collapsible models are great for travel, because they retract inconspicuously into the camera body leaving a small profile that is easy to carry. A specific Dual-Range model was produced with 'eyes' that attached to the lens allowing superior close range ability starting at 1 Meter, 51 or 48cm depending on the production period. This is a fabulous lens, even by today standards.
Are you sure the serial number started with a 7? How many digits?
There's a tabbed version of this lens, but it appeared two versions after the rigid cron (which, in turn, followed the collapsible one that came in 1954). So, if the lens you've seen is black and tabbed, it's the version from the late sixties to late seventies, known as (guess what?) "tabbed."
Now, if it's NOT black, that's not a focusing tab only, but also an infinity stop.
gabrielma said:
S/N starting ...And yes, Wayne is right, "focusing tab" here really means infinity lock. It works like a focusing tab; but it isn't 😉
Somebody make a note of that. Wayne was right once. 😱 😀
Thanks for all the great info! I guess I was wrong about the serial number starting with a 7. But the lens appears to be a rigid cron with infinity lock. Looks just like Wayne's picture and appears to be in great shape, no fungus or oil on the blades. They also had several M3 SS that looked and felt real nice! I've been wanting an M3 for a while - I feel a GAS attack coming on!
