Help identifying LTM lens
Could be a 35mm f.2.8 Schneider Xenogon as well. They have the barrel style of the M2 Summaron f/3.5 but a larger front element (as this lens has) than the f/3.5 Summaron which is slightly smaller than a dime.
Phil Forrest
Phil Forrest
I think you got it. The way it's catching the light looks just like a non-collapsible 9cm Elmar, which (like the Xenogon) has a dished conical name ring, not flat like a Summaron.
Thanks for the responses. At the risk of showcasing my ignorance, I am surprised that that photo was taken with a 90mm lens! The perceived closeness of the subjects to the mirror makes me think that a 90mm lens would have a much narrower field of view. That's why I assumed that it's a 35mm.
However, perhaps the lack of distortion is a clue to greater distance between the subjects and mirror than a 35mm would offer.
Dang, I was almost there 🙄
Being shot in a mirror should have been a clue - it exactly halves the apparent FL (because the distance is halved) so the perspective would be like a 45mm lens, whereas 35mm in a mirror would have looked... strange...
Good to know!
