ASA 32
Thank you for the (mostly!) encouragement and comments.
A 35mm lens is useful when a 50mm lens is not wide enough.
Erik.
... and a 50mm lens is useful when a 35mm lens is not long enough.
The conclusion is then that both lenses are needed.
Erik.
Why not go for a 30mm, it's a little wider than 35, and you can still crop -blasphemywise- to 35 if you need/want to cut out.
You don't have to love lenses just using them is sufficient but after a while you may appreciate having them...
Regards, David
Hmm, I do not remember in 50 years of photography the existence of a 30mm lens for 35mm photography.
OK, it is useful, but what is the best 35mm lens?
Erik.
Nokton 35 1.4 M without barrel distortions.
Erik.
