Help Stuck Shutter!
TRGRichie
3:03 PM
Hello Chaps,
my R-D1 turned up today,
went out for a play but after 15 shots the camera will not take photos anymore - the shutter will not fire!
The camera came with no battery as it was within the EU and aparently youre not aloud to post them!
I am using a 3rd party battery - could this be the problem? - but like I've already said the camera was fine for 15 shots then stopped!
does anyone have an orig battery I could try/purchase if you think this could be the problem?
Update, shutter still stuck with new battery, but if a give the camera a slight knock on the base with the palm of my hand it frees, but then will stick as soon as the shutter is armed again!
Any one know of a fix?
Give this a try:
Insert a not-so-sharp pin into the cable release hole (the hole on shutter release button) and press it, the shutter may fire again.
Sorry if it doesn't work. :)
