mackigator
First off, know that I made a pretty classic mistake: I forgot to write down my settings and now that it is time to develop the roll my memory is clouded.
Second, I need your help to decide the proper dev times, all things being equal, for what I most likely shot.
Here are the facts. I shot a roll of Arista 400 Premium (Tri-X) and I either:
A) exposed it at ISO 400
B) exposed it at ISO 1600
I'm 80% sure it was B.
Now for the tricky part. Most of the roll was shot while also using the Hexar RF's HX-18W flash on a CLE. This flash is not TTL and I was shooting it in its "auto 1" mode as if I was metering at ISO 400 with an f/stop of 5.6. The flash is weak - it has a guide number of 18 at ISO 100 (full power). Looking at the chart on the flash, it should have been throwing light out to about 20 feet set the way it was (ISO 400 assumed).
So how should I adjust my development times to compensate here?
Obviously, if it is opt A, I just run it normally.
But what if it is opt B? And what if I want to split the difference rather then risk it all, so to speak?
I have DDX, Rodinal, and D76 on hand, in case that matters to the discussion. Thanks for your help!
