Canon LTM Help with Canonet QL17 GIII
holgamods
11:17 PM
I just purchased and received a canonet qL17 GIII on ebay. The auction stated everything works and that a new battery came with it. Well, the battery light does not work. The shutter tripped a couple of times before it stopped working.
My Question is......Will the shutter still open and close if you have a dead battery.
Thanks,
Randy
www.holgamods.com
The shutter is mechanical and should work fine as long as you take it off the A setting and set an aperture. If you want a copy of the manual try here. http://pentax-manuals.com/manuals/range/range.htm
Regards
Kim
Thanks,
Randy
www.holgamods.com
