shiro_kuro
Charles Bowen
PatrickT
New Rangefinder User
Gorgeous. Post more!
helen.HH
To Light & Love ...
Yes , Please post more C ...
Love the oof against the Sharp Focus in the 2nd shot
First shot adore the gritty tonal range in the building facade & wires
Thinking about getting this cam to bring me out of my Creative Slump ...
raid
Dad Photographer
Nicely done. Show us more.
shiro_kuro
Charles Bowen
Helen not sure if this camera will cure your photographic blues ,but certainly worth a try . You are an excellent photographer, can't see this camera would slowing you down any . Well maybe in the beginning as there are a lot of button combos to learn ,easy to forget where your at . I'm on my second day and I'm still getting lost in all the options
Tomorrow hopefully will bring some interesting images ,got the whole day to ride the train to wherever .............
danielsterno
making soup from mud
Shiro curious: were these shot in the x100s B&W film options or converted afterwards? RAW or JPEG? Last- not sure if you used the x100 before, is the menu/OK button been improved in user interaction? also, how do you like the images on the xtrans sensor on the 100s versus the non-xtrans sensor on the x100? Personally I think the x100 sensor becomes unique specially if one owns the XPro1, you'll have both out put.....nice work & thank you...
taemo
eat sleep shoot
^here's some pro and cons that someone has been updating with their X100s
http://www.briankraft.com/Blog/personal/fuji-x100s-pros-and-cons/
but the looks from all those that got to play with the x100s is that the OK button has been slightly raised making it easier to click.
however I'm not that overly excited about the battery info and heavy noise reduction that the x100s does on high ISO but maybe more testing will need to be done.
regarding to the OPs photos, thanks for sharing them! all great!
Jamie Pillers
Skeptic
Tonality in these images is gorgeous! Thanks for posting them.
porktaco
wow. these are lovely. camera lusting...
Rogier
Rogier Willems
Great shots!
How did you convert them to b&w ?
shiro_kuro
Charles Bowen
Great shots!
Lightroom /Silver Efex Pro using the same custom preset I used for the M8....
shiro_kuro
Charles Bowen
I have not used the X100 so I can't really compare the two .....
The M8 has been my main camera for awhile and the difference in look is something I will have to get used to on the monitor .... The files on the x100s are simply amazing at higher ISO ...... It really will come down to how the prints look ...The M8 did not disappoint and I'm sure this camera will not either ...
The menu/ok button is fine ... The command dial is not so great but it seem you can use the command control in it's place .... I only found this to be a problem when in the Q menu where it would be natural to use your thumb to change the selected settings ... I end up having to press harder to get a grip on the wheel which would in turn cause a press , activating adjacent menus and causing changes where not intended... spending time figuring out what was changed and resetting ........not an issue if you use the command control instead ....
danielsterno
Thank you for the reply and yes the fuji's high ISO performance is quite impressive but looking forward to hearing your opinion of the print quality versus the M8.... enjoy your new tool! sterno
FA Limited
missing in action
would be interested in any comments relating to
http://www.fujifilm.com/news/n130107_02.html
"The camera uses Lens Modulation Optimizer to reduce optical effects such as lens diffraction, which occurs when light passes through a lens. Even when stopped down to F16, the X100S retains sharpness and texture in the smallest details, demonstrating the extent of the sensor and lens combination's capabilities, perfectly."
shiro_kuro
Charles Bowen
bonatto
looking out
these remind me a bit of MM's rendering. I may be down 1.3k very soon because of these....
shiro_kuro
Charles Bowen
bonatto
looking out
What ISO were these taken at?
